They were all on in the correct order, it was a two barrel though.
I bet they make 400 if you connect them lolI have two we could put together and test if we find a money man to sponsor it.
Due to the crappy heads and two barrel intake.Nah. 400 will run out of air at 3300rpm…
Yup, by '79, they weren't great.Found this on this site. For my truck.
Automobile-Catalog the Catalog of Cars, Car Specs Database
Car Specs Database of hundreds of thousands cars with detailed specifications, technical data and performance data. ProfessCars simulation of car accelerations in road conditions. For each car info on top speed, acceleration times 0-60 mph, 0-100 km/h, 1/4-mile times, detailed photo.www.automobile-catalog.com
None of those engines were turds, and the cam/port numbers on all of them were more proportional to size than the 400Ands what the bent one is ignoring is I didn't give a crap about the horsepower number, just the torque and the rpm that it peaked at. Midrange torque. Period.
No, they didn't have great heads, but look at the torque numbers and the torque peak rpm of the Olds, Buick and Cadillac engines of the late sixties and 1970.
Did you use a 350 to pull it out?Yup, by '79, they weren't great.
The '70 400 that I pulled out of a station wagon was better, and rated differently.
Uh-huh. Sure. Not what I found with mine.Nah. 400 will run out of air at 3300rpm…
But it’s not stock. That’s the conditionUh-huh. Sure. Not what I found with mine.
Mine was stock for several years.But it’s not stock. That’s the condition
Did you win some truck pills with it?Mine was stock for several years.
He’s pretty old, think he might have years on you.@500$k5 probably remembers more of what we found years ago.
That would be great!!!@6872xtc shouldn’t you be doing something else after date night other than debating a antiquated poweplant?
Unless it’s a 305, then all bets are offI thought we was talking stock, if we are talking built , more cubes is better.
No blue pills in the cabinet today?That would be great!!!
29 years of marriage, AND the 21 yr old daughter being home slows things down some...
Or a lot....
No pills..Did you win some truck pills with it?
