exhaust cross-over pipe
AKbigsub
Wasilla, AK
What have you guys done to your cross-over pipe to: 1) clear the front driveshaft, 2) not hang down and snag on rocks, 3) remain emissions legal? Mine hangs down right now but I was thinking about running both pipes from the manifolds to behind the t-case and then crossing over. To do this, the cat will have to be moved aft about a foot. I checked with an emissions inspecter up here and he said the cat needs to be left at the distance from the engine that the factory originally put it. Alaska emissions laws won't allow true duals, even if I dual the oxygen sensors and cats. What have you guys done?
Also, I will be clocking the t-case in the next year so I need the exhaust up so I can fab and install a skid plate.
Oh yah, it's a '90 V2500 Suburban with 10 bolt front, 14 bolt FF rear with Detroit locker, 4.10's, 6" front springs, rear shackle flip with extended cross tied shackles and zero-rate. 350 cid, TH400, 241C.
Here is how I did mine.
I built mine to go under the oil pan. Although my setup is a little different it gives you a idea.
Do you have to worry about emissions with the headers? And how difficult is it to drop the oil pan? I don't see an O2 sensor; I'm assuming this is the rig in your sig, it is the same year as my burb which has an O2 sensor after the Y.
Edit: I just re-read your sig and got your rig mixed up with another one. Yours is an '85 and mine is a '90.
The O2 sensor is probably in the header. Mine is in the factory manifold right before where the Y connects. My plan is to make mine like the first photo. I too have to stay emissions legal.
As far as headers just buy a 50 state legal set and you should be good to go.
Ira
