Exhaust gas question
Redfrog
IL
Why would the driver side bank (drivers side exhaust) be burning richer than the passenger side? or vice versa. It has true duals. One side has more exhaust gas exiting than the other the same one smells richer than the other. Any Ideas?
TIA
HEY Fords!!! how many flushes does it
take to get rid of you
No, that's a silly idea. I can't imagine it being possible unless someone had stagger jetted a carb incorrectly.
You're sniffing too much exhaust. :)
Tim
'84 Chevy K10, lifted, loud, fast, and 3/4 ton axles
Hey guess what, It is possible because it is happening right now in my 79' :) as far as the jets in the carb goes I did not think of that. After all it is a junk holley thanks for the idea
With a Holley it is possible to stagger the jets. That might be what you have here. (I kinda think it's unlikely) If you have a dual plenum manifold, both sides of the engine are fed with both sides of he carb.
Check the plugs, pull the plugs and if you do have a problem, the plug should "tell" you. If one of the plugs have a different color then the rest- something is wrong. Check the gaps, plug wires, and compresion.
