chevysmithz71
The exhaust is hot during and for awhile after the engine is running. Anything other than that, and it will hold the moisture in.
I suspect a lot of that plays on the humidity of the region you live in(?) and how often the vehicle is driven. The more often it's driven the less the problem would be. It may also have something to do with the salt used in many places in the winter.
It should accomplish the same thing anywhere on the exhaust system. How close to the engine is the bushing location? If it's far enough from the engine, it may not affect the poly depending on the distance between the pipe and bushing. I'd go with a sheet metal heat shield or routing the pipe a bit differently if possible.
It isn't close to the engine, it will be close to the pipe after I get the exhaust in. I can't just redo the crossmember. It took many hours of thought and bending to come up with the crossmember. So it's either under the torque converter with the exhaust (where it might get hit with rocks) or run it close to the poly bushings with a wrap and a shield if needed.This is what I am working with.
