Fiberglass top advice
fishman72
St. Louis
I just recently puchased 79 blazer and the fiberglass top needs to be painted. Was wondering about everyones experience in painting their tops, and what works the best! Thanks
I asked this very question a couple days ago on another board and got this response:
I'd sand it smooth with 180 on a DA and make sure she's scuffed really good at the edges and seams then apply two good coats of epoxy primer followed by a urethane or polyester primer surfacer, final sand, then paint. The epoxy will help to keep solvents from being absorbed by the old fiberglass top and also will provide excellent adhesion, the surfacer will give you some build to rid imperfections and also a sandable surface that will be ready for paint.
Colin
just a note on that advice... its very good and technically correct.. your advised to put a sealer primer over your initial epoxy primer, BUT it isn't absolutely nescesary... most will just throw 3, 4 coats of a good high-build epoxy primer on, sand with 320, 400 and paint.. saves ya a couple steps...
an important rule of bodywork is, tho you can hide, fill, etc imperfections with the following coats, you generally want your primer thoroughly sanded and perfect. no orange peel, dings, deep scratchs, etc.. they will transfer thru to your next coat... " your paint is only as good as whats underneath"...
I got an idea for the top... get it line x or rhino liner my theory is that it will make it stronger but then again i could be wrong. i thing at least it would help it from chipping the fiberglass when you take it off and on not to mention keep your body from accidently getting scratched up real bad for those people who care about there body
