I have not, but I discussed it with Bigblock72 before I bought it. He owns the remapping software (he's going to do mine) and he said it would work fine.Have you successfully used the dakota digital vss in conjunction with pcm programming?
Hopefully one of these is what you are looking for because the price is great!Can you elaborate on the 4LO switch or where I can read about it? I have not read about this in my research.Just two quick things, what you could do is get the tail housing and speed sensor off a 90+ 241 cause they are electronic and send out proper signal. Then you would just have to swap to an electronic speedo out of 90-91 truck and you would be all good to go. Family common swap. The other thing to remember is no matter what, you have to install a switch to tell the computer when it's in low range. Otherwise, the computer will think the Trans is crazy slipping.
Does it have a seperate light for low range? Cause you wouldnt want it "activated" in just 4hi.
I see, good point sir. I got some more information from Brendan; There is not an inline VSS manufactured that will properly run the 4L60E, he said an incorrect or erratic VSS signal will lead to premature trans wear. So now I am considering a new adapter between the trans and t-case that incorporates a factory VSS. Any thoughts? Where can I get the least expensive adapter? Is it Teck that is running this setup?![]()
I'm thinking your best bet would be to find to the tail shaft housing from a VSS equipped 241 from a 90-91 K5 or Burb like y5mgisi mentioned earlier. The only small issue there is that you would also need an electronic speedo from the same year/model truck. If you can't find what you need locally let me know. Last time I checked the yards near me there were a couple that had those trucks and I believe they wanted around $30 for the tail shaft and around $40 for the speedo or $46 for the whole cluster. I could grab them for you but I'm not sure what the shipping would be from Cali...
I just found the write up on the conversion by a member. Sweet infoIm not to sure if they will swap. But i would bet yes. As for the electric swap, probably best to do a little googling on that one.
Here you are, props to "jeff in co" great write up!Dont suppose you have the link? I will probably need that information when i do the swap on my 78 also!![]()
