Triaged
Building up a 14 bolt full floater and a 3/4-ton 10 bolt or Dana 44 for the front is a very good idea. You can get the 14FF very cheep (under $100 is cheep to me) and they are VERY easy to find and hard to break. You don't need a D60 up front so don't waste your money. Sometimes it is cheeper to get a matched set of axles to toss under your truck...but you can convert your front to 3/4-ton by just swapping the brakes.
When you lift it keep it low! The higher you lift it the worse it will tow. Also the better it does offroad the worse it will tow.
If it was my truck I would do some somewhat stiff 2.5" leaves up front, an ORD shackle flip out back with some stock 3/4-ton 56" leaves (and adjust the shackle flip bracket to work). Stick with 33" tires and 4.56 gears (you have OD right?). Some adjustable shocks might be nice for when you tow. The steering box brace is a no-brainer. The frame on those trucks is VERY weak. When you put the brace on take off your steering box and weld up any cracks you find.
) then buy axles, then get rims and tires
