This thread is funny. Mains, Rods, Heads they need torqued.
Dragonslayer - Small Block Chevy
3.7503502.100LT-1 1 Pc. Seal, Camed for 5.850*CAJ11A-DS$1079.99
Oh your welcome.
I can't for the life of me ever remember there being this many trolls on this site. If you have nothing to offer to the main topic please don't post and since that questioned has been answered it would seem ever post after that is a bait for no other reason then to troll.
Ever break the ear off of an aluminum intake manifold? Ever crush an oil pan gasket and it leak? Ever strip out a harmonic balancer pulley bolt hole? Ever crack a case iron exhaust manifold?
I would say thank you, but since I followed the recommended torque on the flexplate I'm not in the market for a crank.
ok to untroll a little i will tell you this. Every fastener on a gm vehicle has a torque spec. This is mostly to prevent what you said about breaking or overtightening. Still in most cause its just to prevent the ham fisted and unknowing from breaking stuff. Martin may go a little overboard on his suggestions but anyone who has worked on cars for awhile will tell you it will work the way he suggested. I don't break stuff because i understand how tight to tighten stuff. I am not saying my arm in calibrated but if you use a 1/4 rachet to tighten oil pan bolt it's pretty hard to over tighten them. Same with using a wrench on intake bolts. I am sure you just want to do the right thing cause you have a new engine and don't want to mess it up. Just remember at some point its stupid. Seriously to you use the belt tension gauge to tighten belts? The a/c brackets to engine bolts should be 21 lb/ft. Starter should be 28lb/ft. Spark plugs 22 lb/ft. The only other thing i have to add is saying a engineer figured out how to tighten it carries very little weight. I have found most engineers to be some of the most ignorant, non-mechanically inclined group i have ever met. I once spent 45 min telling one how to remove his wheel so he could paint his caliper. So in short do what you want, don't worry about marty, but remember right/wrong can be a little ways apart.
If it involves Troll never mind.
Just curious.
He torques everything and uses the book religiously. Just makes me think about Cooters garage. We are all a little back woods but that doesn't mean we are teh dumb.Almost makes me embarrassed to say, I'm an A&P Mechanic myself. Got to live by the book!
I think this is what Tim was getting at. it's OK now and then to just tighten it till it stops turning. But, use you head about it. If it's possible to really wreck something, stop, break out the Torque wrench and do job correctly.
