I have been doing a lot of research here and it seems like everyone that puts on ford shock towers ends up cracking their frame? Or making shock towers ends up cracking their frame. Is the only way to prevent this is to make an engine crossmember to go over the top of the motor connecting the two towers?
How many people have cracked their frames? How long you have used it? What type of use does your truck see? thanks!
) as well making sure the shock doesn't run out of travel in either direction. Also you don't want your doubler/backing plate edges to line up with with the edges of the tower - make it wider/narrower by at least an inch.
