Free th400/208 in Oregon
COCHEV
Washougal WA
I have a Th400/208 with adaptor and crossmember pulled from my 83 burb when I did the 4 speed swap. It ran and functioned just fine, but I'd concider it a builder. It does have an aftermarket deep pan with drain plug. Its not a K-case. In fact, i believe it is a diesel trans as the flex plate/converter had 6 bolts. The T-case worked/shifted just fine- might need to be re-sealed.
FREE if you come get it out of my shop!
