aj's tonka truck
Registered Member
- Joined
- Jun 29, 2004
- Posts
- 53
- Reaction score
- 0
I have installed a dana 60 axle under my 91 blazer. I plan to install the EZ INCH from DIY4X in order to move my axle forward 1.5 in. and to give me an extra 1 in. of lift for the HD bumper and winch that I plan on installing. Question is, will this affect the front shock when I go to install it? It seems like it may cause a problem. Has anyone out there moved their front axle forward on their blazer and if so, what problems did it cause and how did you fix the problems? Also, is 1.5 in. to much to move it? I could just move it 1 in. I would rather the 1 1/2 if no problem. Once again, I thank you for the help.
