Front shock relocation for 1st gen
70jimmy
3/4 ton status
Staff member
Moderator
Released from Pueblo, told I belong in Southpark
The new axle I am putting in the front of the jimmy has the shock mounts at the outer edges of the axle. Anybody know where I could get a shock relocation kit. Any problems with doing this. The shcoks would be vertical but angled to the new location if that makes sense. thanks.
Just in the middle of bolt on axle swap!!!! :mad:
I don't have the address but if you search the project UAV specs or search on this ORD forum you can find the writeup Fox did on his ford shock mount install and that should walk you right through it.
