chevysmithz71
I just took the Blazer out after a th400 and a Stak swap. The radiator was all over the place. I have the wheel wells removed and I'm sure that took away some support. With only the top and behind door bolts holding the rear of the fenders on probably doesn't help either.
So to those NOT running wheel wells, Did you brace it up some how??
Was thinking of adding more tube and tie it into the radiator support somehow. Planning on narrowing the front now that the 42's are on and will chew up a whole lot. Those that have done it,,,,,,
Is it better to just go Tube up front or keep the radiator support for simplicity??
