@4X4HIGH @Russell and at all you other TBI gurus.....
I recently replaced my engine with a crate long block. Freshened everything up under the hood too, though I didn't replace my distributor (probably could use it though...)
It runs great, but I'm having an ongoing problem that it blows a huge plume of white smoke shortly after start up. It does so until I get on the throttle under load, at which point it clears up permanently. The colder the engine, the bigger the problem. If I idle for a long time, the smoke comes back. I think this indicates that the cat had cooled.
I had the intake gasket replaced to confirm no coolant leaking into the combustion chamber. Tested it for a bad head gasket. All came out OK.
Timing mark bounces around a fair amount when timing.
The smoke smells like I'm running rich, and I think the smoke clears up because the cat is getting hot and burning the unused fuel. I did have some terrible passing smog because I was running rich.
Then I started getting a code 43 on the SES light every so often. Sometimes I lose power suddenly when hitting the gas for a down shift, which triggers that. A little reading suggested that it could be a knock sensor problem. I replaced mine, no improvement.
But I'm wondering if this has to do with timing and fuel delivery problems leading to an excessively rich mixture.
Please help. :-)
Please help. :-)
