A big warning to all fuel injected truck guys.
I was checking the transfer case on my 91 K5 that my son drives and was smelling gasoline while under the truck. At first I couldn't see any obvious leaks, then as I was checking the lines along the frame I found that the flexible braided steel "protected" hoses that run from the frame rail up to the TBI unit have been rubbing on the transfer case support rod and had rubbed a hole in both of the fuel lines. the leak was dripping down onto the exhaust pipe.
I had the lines from my 87 K5 that I figured I could use so I took them off only to find that they also had rubbed holes through the braided steel protection.
Plan B, I took the flexible lines off my 93 K10 chassis to try them out. They are different but worked out perfectly as they are longer so I ran them a different way to avoid being rubbed through again.
I recommend everyone running fuel injection to check their lines to make sure there insn't any issues with the factory routing of the lines.
I think if both of my trucks had the same exact problem with a factory design that has a potentially devastating result then I thought it worthy of warning the brotherhood of a risk.
