Full Rubber Mat K5
penxol
california
Wanting a full Rubber mat for the whole interior of the Blazer, not that one LMC sells think its MIL, just rubber or Vinyl.
Any Recommendation ?
Auto custom carpets. That’s where I got my mat from. Keep in mind there isn’t a full front to back mat. They are two parts, front floor and the back cargo/load floor. The front covers all the to the rear seat footwells and to the load floor. So it is 100% covered when you use both.
How'd it fit?
How'd it fit?
Ok. Not perfect but part of the issue is the front section is oversized. I trimmed a lot from the area under the dash and door sill areas. I should have left it in the sun longer to soften up too because it is fairly thick and a couple of wrinkles were harder to work out.
Once it was in and trimmed out it look’s pretty good. It just took more work than I expected for a big chunk of rubber. Though the rear was a no brainer. The main section laid flat and contoured around the wheel tubs perfectly. There are separate sections that go over the tubs too. Put those on first so the seam between the floor and tub is clean. The part that goes to the bedsides may require some trimming but that depends if you have the interior side panels or not. If you don’t have the panels you’ll need to trim that side flush to the bedside where the tub joins it. If you have plaice panels the excess will be behind then and don’t require trimming unless your ocd takes over.
