toomany submitted a new Build:
FullSize S10 Bogger/Mud Racer
Read more about this build here...
I guess you could call this a build thread. Mainly going to try to use it to keep track of my progress/notes/bounce ideas around.
I've been using my K5 as a bogger in the local bogs, and while it works great it has some downfalls. It's heavy (for a comp rig) and the manual transmission isn't doing it any favors. The motor that I run for the bogs is all top end, not good for daily use/trails (which is why I swapped it out for the Bundy Hill run).
A couple months back I picked up an 86 K10. I originally bought it from a high school friend, sold it to my cousin then I bought it back. Truck has 60/14, 350/465/205, solid cab and pretty trashed front clip/box. Plan was to use this as a bogger, gut as much weight as I could and go from there. I've been collecting parts for this for awhile but there are still quite a few things to get.
Before I even started with the K10 I got to thinking of way to shed weight, what's lighter than a K10 cab? One half the size, so the hunt was on for a solid S10 to steal the body from. I saw a few for decent prices but they were rustier than I wanted to start with. Eventually a solid cab/clip showed up for $300, picked it up for $200...figured I find some box sides later. Well later came around about a month later when another one popped up for best offer before it hit the scrap yard. $100 got me another really clean cab/clip/box, Only plan to use the box but the fenders are good for mock-up...plus it's nice to have spares.
Eventually I will run a BBC, but to get things going I'm going to start with the SBC that I had in the K5. Transmission will be Th350 hooked to a 205. Will keep the 60/14, re-gear to 4.88's or so. I've also got a 10 bolt I could use up front to lose more weight/gain ground clearance.
So far I've gotten the K10 stripped down and the S10 cab mounted. Working on the front end. I've put the BBC in there to give me the "worst case scenario" on clearances. So some of the pictures have the SBC and some have the BBC. Only have a few random pictures as of right now, will take some more once I get back out to the barn.
What I started with. I've got some more pictures of the blue truck in my K5 thread. Put my Boggers on because that is what the truck will be running. Obviously this is mid tear down. Truck cab is real solid. The box has seen better days and the front fenders are getting real bad....
