Metalhead47
Got to pulling my dash apart to install a tach today & discovered some PO's alarm box was still stuffed up under there, so I wanted to see about removing it. Since it's an alarm I don't want to go cutting wire willy-nilly for fear of not being able to start the rig after. Anyway, followed a wire to the fuse box. What are these connections above the fuses? (on the left in the pic) They almost look like built-in power taps. The purple wire with the crimped connector goes to the alarm, the other connections look professional if not factory. Help?
) so yes. There is a spare white wire coming off of your coil. That's your tach lead.
