digitalepiphany
I'm in the middle of rebuildiing my carburetor (Holley Street Avenger 670cfm), and have learned a thing or two about gasket removal.
I assumed that the carb cleaner that I was soaking everything in would be enough to remove gaskets. The throttle body gasket did not want to come off. Carb cleaner is not good enough. I bought some gasket remover, and it came right off. I did let it soak for about forty minutes, but it was definitely worth the extra $10.
So, if you have gaskets that need to be removed, use gasket remover, no matter what other stuff you have lying around that you think will work.
If any of you have any other tips for gasket removal, please pass those on here. I'd love to know, because if I have a similar problem on say my valve cover gaskets, then gasket remover wouldn't really work, as it could drip down into the oil.
