Hey all,
I'm checking the pattern on this 14bff. It has 34 lbs preload(all new bearings, both pinion and carrier) on the pinion with the seal in place and I've got backlash at .004 right now. I'm having issues with getting a good pattern, but I think that's because I'm trying to get it with just someone holding a disc brake with gloves and an axle in.
Check it out.
and
It starts low then goes middle then high, but I think that is from not getting even pressure through out the pinion turn.
Thoughts?
Check it out.
and
Thoughts?
