So, what is involved with testing the alternator?
2) Discuss the reliability of auto parts store testing.
3) Can i do any or all of the testing at home?
MAX Voltage output test
Use a digital VOM and attach it to the B+ post on the back of the alternator.
Ground the other end anywhere that is bright metal
- I like the brake lines for a ground as they attach to the master cylinder.
Start engine (make sure the battery is decently charged)
Insert a short piece of paper clip* into the small "D" shaped hole in the back of the frame and watch the voltage.
* No longer than 1 inch enters alternator.
- you can't reach very far with a 1" probe.
Just make sure that the probe also touches the side of the D-shaped hole, as that's the ground for the alternator regulator test you're doing here and it carries very little amperage.
DO NOT BE AFRAID OF ANY SPARKS AS THEY WILL NOT HURT YOU AND THEY SURELY CAN'T BE FROM ANYTHING SOPHISTICATED that you might have poked inside the housing.
You WILL hear the alternator LOAD-UP and perhaps even the idle speed may drop a bit - this is good.
Down and dirty DIODE test: (very accurate, really!)
Start engine, let idle
Check the DC output from the B+ lug on the back of the alternator using the AC Volt scale.
(yup - that's right, the AC side of the meter)
AC volts should never exceed 0.013 VAC output on the B+ lug. Never! .
If your result is higher than 0.013 VAC, the diodes are in trouble.
Replace alternator (as many times as it takes to get a good one!)
If you have a Cold Weather/Low RPM, Digital Exciting System (DES*) in your vehicle, the AC Voltage diode test is a little trickier.
This DES System didn't show up until about 2001 and UP models of GM HD alternators IIRC.
*This first showed up in Cadillacs I think, circa: 1999 or there about.
You can test the DES system if you are sure that the battery is very close to charged and the engine/battery is not below 40ºF while it is running.
The DES is a supplemental system to artificially excite the alternator to put out a lot more amperage at idle and at low engine RPM in cold weather and right after start-up, by hitting the stator with high frequency signals to increase the 'pull-break' cycle inside the magnetic fields inside the alternator. .
DES
MAY come in and out at low stoplight-crawling speeds and some alternators will really make a loud squeal if it has a slightly loose iron field core lamination, etc.
The noise itself is harmless - more a bother really - but it can attract the attention of nearby drivers.
Normally one can hear a standard alternator 'cutting fields' when it is idling - kinda a low volume whistle/squeal. It too is perfectly normal.
________________________________________________________________________
Now about the store testing: Ahem!
If you think that your parts 'dude' or 'dudette' behind the counter was just yesterday asking if you want to SuperSize your Fries ..... well.......
In-store testing is prolly decent enough as most testers are computers with onscreen instructions that tell the operator what to do, and then if the green bulb lights up - it is OK.
HTH.
