GonicGM
Used OEM 4.56 14 Bolt FF 10.5" Ring and Pinion $85
will include special longer ring gear bolts.
Which one sold? Ring gear or pinion, or both?Carrier Sold!
Thats why I had to ask. Just wanted to verify the pinion support carrier was still attached.Neither.
The image shows a pinion gear (in support) and a ring gear bolted to a (differential) carrier.
Per post:
"Carrier Sold!"
That leaves a ring and a pinion and ring gear bolts.
(ring and pinion+carrier)-carrier=ring and pinon
What is being sold is an OEM 4.56 ring and pinion with special longer ring gear bolts and lock washers. Disregard all else in image.
Very old and I know the carrier went, but are the ring and pinion still available?
Great! No rush. Planning the swap for just after Christmas. Keep me posted and let me know a price.
Don't know if you can calculate shipping or if it would stuff in a flat rate box, but it would be to 30306 (Atlanta, GA)
PM'd
did they sell
you still have the ring and pinion and the mount for the pinion
if so how much to 94110 it should fit in a large flat rate box i think
pm me if you still have
