I haven't but I'd think that if you used either coil springs or coilovers. That it wouldn't interfere. Leaf springs the brackets would definitely be an issue I'm thinking.
v-plows HATE taller trucks . the A-frame needs to sit flat in relation to the ground . there is a setup directions list on how to set them . otherwise they will not scrape 100% of the width when in V or scoop .
so if you plan a lift and tires also plan fabing some plow mount lowering brackets .
So, I think have a line on a 05’ super duty front end
That will solve the plow mount issues , just a bit more Fab to make it happen.
A friend had one with a sas with leafs and a plow, but he built an undercarriage to mount the plow. The front of the undercarriage hangs on the front of the leafs, then goes underneath the front axle and then angles up and mounts to the frame with brackets near the transmission cross member.
I have a similar undercarriage on my ‘87 V30.
Any chance on some more pics? I have considered something similar on my current plow rig so I can keep the crossover steering.
I don’t have any pictures of his GMT400, and it has been parted out. If pictures of my ‘87 would help, let me know, I will take some.
