Got Me A '05 6.0 - Need Flywheel
Upstate
- In Memoriam -
New York
Ok, I have the Advance Adapters bellhousing to mount the 6.0 to my NV 4500 and have all of the hydro clutch crap to hook it up. Now I need a flywheel to give me the correct spacing (.340 thicker) for the 6.0 to bolt to the NV 4500.
I already have new clutch and pressure plate from the SBC 350 I have. That should bolt up fine, no? 10 spline 12".
I know that '06 4.8 and 6.0 flywheel will work but over 40lbs. GMPP makes one but over $300
GM makes one that you can buy from anywhere with GMPartsdirect.com being the least expensive by a fair amount. That part number from GM is 12561680, pressure plate ram 88744 and bolts are 12561465.
I decided only because I am using Advance Adapters bellhousing to use their clutch kit or 712500m. In hindsight I likely wouldn't do that again. That being said I have read where people had issues with 12" clutch with the AA bell.
