got some new fab goodies, pics.
rdn2blazer
1 ton status
- In Memoriam -
So Cal.
Ordered some new stuff from DIY, Ruff Stuff, and a vendor from pirate, Balastic Fabrication. All three are great companies. Even though Balistic Fab is not a vendor here I can recomend them 100%. Fast shipping, Quality parts, easy to deal with.
Sleeve's & Bushings are from DIY.
Simple D60 swap kit for Ruff Stuff with a Ford 3" wide plate for running a "U" bolt on the housing side. A better setup then the weak usually stripped cast threads in the center section. Will have to groove the casting just a bit to allow the "U" bolt to work but no big deal. Also will have to drill a hole in the webbing for the "U" bolt to go thru. Don't really need the pearches but ya never know when you might have to re-locate them. Came with new weld on shock brackets. Also bought a spare tire mounting plate. Going to make myown rear bumper at some point so this should help with that.
I got the cage flanges from Balistic Fabrication. I drew up some 1 3/4 cage flanges I wanted to make, And found the exact same thing on their site (4th pic). Saves me the trouble of having to make them, How cool is that. The time it would've taken me to do them is not worth my time considering how little cost they are. The clamps are 1 1/4 ID tube clamps. Using those for the new custom streering colume & brake booster mounting setup I'm building. I'm stoked with how it's turning out. The two hole flanges are for this setup too, are 1 1/4 ID.
