Governed vs. Non-Gov. TPS
longbedder
3/4 ton status
Staff member
Moderator
Ridgecrest, CA
Engine = 1994 TBI 454
The parts stores have an option for the throttle position sensor: Electronic Governor or Without. They look incredibly alike.
What would the difference in the TPS be between the two :confused:
On a side note, I'm pretty sure the governor is a programmed thing in the PROM - mine is aftermarket (Whipple) and is not governed anymore.
I have no idea. Are they actually different part numbers?
I would take an ohmmeter to both of them to see how they compare to the one you are replacing. I have heard of some TPS being backwards from others on GMs. For some reason, they don't always get a different connector. If you had one that was backwards, all you would have to do is back two terminals out of the connector and swap their locations.
