rampage
3/4 ton status
You sure the battery isn't running low? Sounds like you've been cranking it for some time now. Might try jumping it to see if it helps.
It isn't that unusual for an ignition module to fail out of the blue like that.
Did you try a new ignition module?
ok... here's my concern now. did plugs and wires 4 days before this problem. it ran and drove beautifully after that... new rotor, new coil today. still no dice.... apparently I have a much bigger problem here
Yes. Mine has them.
IIRC, the feds mandated the 3-point lap and shoulder belt in '73.
I think it was 78 in trucks. I had a 73 and a 75 and neither had 3 points.
Look for yellow parts in the ignition system. Yellow parts are typically made by Accel, so a yellow coil, or module would probably be dead.I have no spark.......
If you changed the cap and rotor during your tune-up, check them to make sure there wasn't a simple assembly error and something has come loose. Make sure the carbon button is in place with nothing melted around it.
Carbs are designed to work within certain parameters. As off roaders we usually put them to use in situations well beyond what they were designed to work in. Add 30 years of age to that unit and that opens it up to even more failure options.
) I decided to keep working on it myself.
(((( boooo.......
