I bought a 2 ton Engine Stand and 2 Ton foldable shop crane from HF since I had a 25% off coupon. Seem to be decent for the price. I haven't picked anything up yet though...
Anyone know what bolts/washers I need to bolt a big block to the engine stand? The mounts have long pieces of small diameter pipe on them (like 2"), so I need a bolt that will go through there and thread deep enough into motor.
Also, are the accessory brackets strong enough to lift the motor from for the front mount? That power steering pump bracket is really easy to get to, but if those aren't strong enough I won't use them. Thanks.
