Harness pinout for gauge cluster?
The t-case is a direct swap. The 88 has a mechanical speedo and the 91 has an electric speedo so you will need to buy an electric speedo from Autometer but not sure what you'll need to do about the reference signal to the ECM as far as speed input goes. Since you have both vehicles you could always trace the wiring and see if you can rob the proper wiring to put into the burb as well.
