Xtremjeepn
So I totally rewired my crew cab project wtih a "Painless Wiring" harness. (most of the original wiring was simply missing when I got the truck shell.
Here is all Painless has to say in there instructions for the wiring of the heater.
I've done that and still have no functioning fan/blower. (my truck is heat only no A/C)
There is a group of wires labled for the heater blower wtih a plug for an A/C blower relay. (which I don't have because I have heat only).
They don't give any sort of schematic for this at all. I have no idea what to test/splice etc.
NONE of the wires going to the heater or the extra set have power going to them at all. (key on). I need to figure out which wires should have power and where do they get it from?
If I add the A/C relay will this power the system? (Is this relay something the local autoparts store should have?)
Thanks.
Heat Only
8.9.1 Units with heat only will connect wires brn #904 and brn/wht #967 together in
AC Section A using a blue 1/4" push on connector. Attach as per Diagram
#9.
Note: The tan wire #969 will be omitted at the switch and the
resistor. Tape and stow away. The grn wire #902 will also be
omitted in Engine Section B and in AC Section B, because there
is no compressor. Tape and stow away.
Thanks.
