mud_flinger
Registered Member
i look forward to reading all the info i've been told that is here.
but right now i have the need of an engine guru. the motor in my 78 k5 is swigging oil, i just had the heads rebuilt because i thought that was the problem, but no, still using 2 qts oil a day, and i have a friend who has a vortec shortblock with less than 50k miles on it. he sold the heads, as they seen to be in big demand. but he has offered it to me for a swap of some labor on his truck.
he let the engine roll over off the blocks it was sitting on and it dented the oil pan up pretty good, and it has a PLASTIC timing cover on it. will my metal timing cover go in its place and will my oilpan fit it also? and my older heads, will they bolt up to this engine, sorry for the ignorance, i've never worked on anything newer than an 82 model gm. is there anything else that i need to address to use this newer shortblock with older heads, intake and tin? i've looked around your site and i see alot of stuff that will get done to my k5 as time goes by, wish i had found this place years ago!
