lochenjons
Ok so originally I wanted to place the front spring hanger directly underneath the body mount but I don't have what I need to make the hanger flat on top so it can bolt to it. I was going to go with 5.25" long shackles.
OR I could move it in front of the body mount like the ck5 article and go with 7.25" shackles. I'd also put togethor a square driveshaft. But with these much longer shackles, will this screw up the caster angle and all? I wanted to go with the first option since the shackles wouldn't be muhc longer and the dshaft wouldnt be moved forward and there was a chance I oculd keep the stock one, for awhile anyways.
EDIT: Now I see in ck5 writeup he moved the shackle hanger forward it look like too, well I'm not moving it so I guess I'd use shorter shackles?
