So I'm about to tear my K10 down to the frame (again
) and the brakes need some addressing. The pressure switch on my proportioning valve has failed so my brake light is on all time despite nothing being wrong with my brakes. It's my understanding that the pressure switch can't be replaced by itself, the whole proportioning valve has to be replaced. So my plan was while I had the brake system apart was to replace the valve. But then I thought, hey my rear brakes lock up very easily and far before the fronts do, maybe I need a different proportioning valve (like from a 3/4 ton) or maybe an aftermarket adjustable one. But, can I get an aftermarket valve with the switch built in? I'd like to retain the brake idiot light in case of a brake failure.
My other thought is that I'd like to add a line lock to the system to get those effortless burnouts
and easier holding on the boat ramp without having the to shut the truck off in gear. So then how the hell do I add it to a the system I'm trying to set up?
) and the brakes need some addressing. The pressure switch on my proportioning valve has failed so my brake light is on all time despite nothing being wrong with my brakes. It's my understanding that the pressure switch can't be replaced by itself, the whole proportioning valve has to be replaced. So my plan was while I had the brake system apart was to replace the valve. But then I thought, hey my rear brakes lock up very easily and far before the fronts do, maybe I need a different proportioning valve (like from a 3/4 ton) or maybe an aftermarket adjustable one. But, can I get an aftermarket valve with the switch built in? I'd like to retain the brake idiot light in case of a brake failure. My other thought is that I'd like to add a line lock to the system to get those effortless burnouts
