Harrison84
Registered Member
Just purchased a 1984 jimmy. Well every since I got it have had hell with wiring And gauges. Anyone who has time to help me. Would be appreciated. [email protected].
No bad bulbs.For the turn signals, Fast Flashing and indicator light staying solid are both symptoms of a burnt bulb. check all the bulbs, make sure they are seated properly and the sockets are clean
The 4 wires on the tank are from a fuel injection tank 2 wires for the electric pump and 2 for the gauge.Light problem was the ground. Got that fixed. Blinkers still blink fast tho. Fuel pump has a grey, purple, black, black white wires. Gray and black are connected.
Grey is 12V for the fuel pump. Purple is the sending unit. Black is ground (used by both the sending unit and pump). Don’t know why you have a black/white.Light problem was the ground. Got that fixed. Blinkers still blink fast tho. Fuel pump has a grey, purple, black, black white wires. Gray and black are connected.
