1986 Chevy K30 one ton. Dana 60 / 14 bolt - 40" MTR/s
Hopefully someone is running something similar and can help point me in the right direction.
I'm running 6" front springs up front. With the weight of my big block, I would say i'm around 5" of front lift. I'm having some front drive shaft binding and really don't want to do a T-case drop. I was thinking of bolting in the solid steel shims (2 on the passenger side and one on the drivers). From what I have read, seems like I don't want anything over 6* to keep it roadworthy on the street. I am torn between the 4 and 6 degree shims. I am leaning towards the 4 degree ones to be safe.
I guess my question is weather or not I should do 4 or 6 degree shims. I will also be clearancing out the drive shaft for a bit more angle here soon.
Any thoughts?
Any thoughts?
