After being sidelined with a health issue all winter, I finally decided to hire a guy to install a few things on my 1984 M1008 CUCV (1 ton pickup). He's working in my shop, and seems to know what he is doing.
The Plan: 1" Zero-Rates, 1" Body Lift, Poly Body Mounts, Steering Box Brace, fender trimming, and 315/70R17 (35") Treadwright Guard Dog MT's on Pro-Comp Black Steel wheels.
The Problem: Once the Zero-Rates were installed, The Dana 60 front axle appears to set crooked, in stock form it appeared to sit square and correctly.
The passenger side, by appearances and measurement from the fenders, sits about 1 1/2" farther back than the drivers side. The center hole on the Zero-Rates was used, original spring plates with sway bar removed, and new U Bolts.
The pickup drove fine in stock form, but would in 2WD pull a little to the right when the hubs were locked, which was attributed to the Power-Lok limited slip. When locked in 4WD, the pull to the right was less but still noticeable. When the hubs were unlocked no pull was noticeable. The guy who installed the Power-Lok said that was not unusual. He runs an off-road and truck shop and rebuilds axles and installs lockers of all sorts on a regular basis.
We have measured everything imaginable, the frame does not appear to be sprung, and things seem to check out OK except for the tire position in relation to the passenger side fender.
Could the fenders be out of alignment? By appearances they fit a little different on each side, but not majorly.
Could the cab be out of alignment with the frame? The front bumper does not line up with the cab perfectly, 3/4-1" gap on one side, and flush with the other.
Could the passenger side spring have more sag than the drivers side? The passenger side does measure 3/4-1" lower than the drivers side, which I understand is not unusual for these pickups. I do have another set of used springs, poly bushings and greasable bolts that could be installed.
We dropped the axle again and can't see anything wrong with the install.
Any ideas and suggestions would be appreciated!!!
