Help!!
blazinbg
Registered Member
california
Ive got a problem my voltage gauge is reading real low at the red mark right before the 8volt. ive load tested the battery and the alternator and they check out ok ive used a multimeter at the battery and reads 12.??? when off and 14.2 when the engine is running is this a common problem when the gauge is going bad?
Also when I put the truck in in gear drive or reverse it turns off I was told it maybe my torque convertor?
Please help. 83 k5 350tbi 700r4
Sounds like the gauge is bad, and your convertor is locked.
