Mudstud
I saw you had posted a pic of your front end and noticed your steering gear box had the assist ports side by side. I have never seen this before. Who did the drilling? Have you tried it out? I like this option better then one under the other because you can go in as far as you need to with the tap without having to grind the tip down. Looks like the forward most port is in the typical spot and the rear one is what, about 1.5" behind it?
Here's the pic.
Here's the pic.
