Hi-Steer Tie Rod length please
silveradoreb
Boone,NC
I am about to go hi-steer ie buy another arm from ORD since I have his x over. Well I made a 1.5 .250 wall DOM tie rod in the stock location using weld in tube inserts and 1 ton TREs. We obviously I need a shorter on for Hi-steer, so I am going to cut one end off, weld in a new insert, so anyone with a measurement on a Hi-Steer tie rod, without ends. Stephen wasnt sure off the top of his head, and I cannot measure, cause My truck is at school.
haha i can get you a measurement from mine, but mine is reverse hi-steer, i think it should be about the same length. give me some time and ill get a length for you today
well ended being busier than i had though, ill get a measurement tomorrow morning before i go to work. merry christmas
I have skys histeer kit and my tie rod is 48". Its about an 1" shorter than I'd have made it. Im just going to double up on jam nuts.
:xmas:
I wanna say my one on the front was 50 with no inserts or ends, so, I think I will cut it off right behind the old insert and weld in a new one. Thanks for yalls help on christmas.
