High pressure in cooling system
Discussion in 'The Garage' started by imiceman44, Sep 9, 2020.
  1. jake 03
    jake 03 1/2 ton status Premium Member
    Feb 12, 2011
    311
    41
    Burlington,Co
    Build(s):
    That kind of pressure and it holding overnight cant be from just the water heating up/air pocket. If that WAS the case the pressure would dissipate and be completely gone after the engine cooled.
    Something has gone wrong with what you did,defective/damaged head gasket,debris on block or heads causing it not to seal- something of that nature.
    Best bet would be to run it with the crossover off and figure out which bank is the issue,then pull the head and look at everything very carefully.
    campfire likes this.
  2. Jonah Gregg
    Jonah Gregg Registered Member
    Jan 21, 2017
    7
    20
  3. campfire
    campfire Adventure is out there! Premium Member
    Jun 7, 2013
    24,820
    13,962
    Northwoods Wisconsin / da U.P.
    Build(s):
    3
    Deja vu. I have exactly the same engine and exactly the same problem (though yours sounds more severe). Coolant test indicated no combustion gasses, but it will hold pressure for weeks at a time while stored. After thinking it over for a couple years, I have concluded I must be getting combustion gasses into the radiator. However, my problem has been coming and going for about 2000 miles. It went away for this whole summer and just reappeared on the last day of the offroading trip. No visible contamination in the oil, nor do I see steam in the exhaust. I have though that it's possible I'm getting clean air from the turbocharger, but that would be less likely. And it definitely would not be giving you 28PSI. Mine doesn't seem to actively burp while running, it just holds pressure after it cools down. It's been minor enough that I've just been driving it. And, like I said, the problem went away for about a thousand miles before reemerging briefly on the trip. It's weird.
  4. campfire
    Jun 7, 2013
    24,820
    13,962
    Build(s):
    3
    It sounds cool, but this blog posting is overstating the advantages. Firstly, waterless ethylene glycol and propylene glycol are readily obtained at any automotive store. That's what full-strength automotive antifreeze and RV antifreeze are. So there is no need for the expensive product. Secondly, traditional antifreeze mix does not boil at 212 degrees. The mixture will boil at somewhere near 250 degrees. The pressure valve in the radiator cap allows pressure to build, restraining internal boiling even when it is running hot. When heat gets excessive, the cap opens and allows some coolant to boil and leave the radiator. This removes heat from the radiator and provides a safety backup cooling method if your water pump does fail. The non-boiling pure glycol cannot take advantage of this ability until it reaches 375 degrees. They are advertising this as a safety feature, but what that means is that the boil-off mechanism won't engage until the engine is thoroughly ruined by excessive temperature. The higher boiling point sabotages this important safety feature. Fourthly, scale buildup is a function of chemical interaction. Use clean water, and periodically flush your glycol (as the corrosion inhibitors break down), and it should not be an issue. Fifthly, as stated towards the end of the post, propylene glycol only carries about 60% as much heat energy as water (80% as much as a proper mix). Do you really want a cooling system that is only 80% as effective as stock? Yes, it warms up faster. But that's not actually a good thing unless your cooling system is significantly oversized. Reduced carrying capacity is particularly harmful to head castings, where heat gradients tend to build up.
    The post also indicates that this particular coolant is prone to corrosion issues. So the auto store glycol might be better, as it will come with additives to manage corrosion. But, either way, pure glycol is not going to remove heat as well as a traditional mix.
    frankin5 likes this.
  5. imiceman44
    imiceman44 Hoarder extraordinaire Premium Member
    Aug 5, 2002
    22,045
    5,850
    Lincoln, CA
    Build(s):
    5
    One of my first thoughts was that maybe somehow pressure from the turbo is getting in the coolant.
    I am still investigating this.
    I will be soon changing the water pump and at that point I will first try to check the 2 sides by removing the crossover pipe and belt and see if anything is coming through there.
    If I see one side has a problem I might deal with it and fix it.
    If both sides are a problem then I will pull the bolts and put studs and probably the thicker head gasket
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    11,515
    2,772
    Grand Rapids area
    Build(s):
    That was my thought. I seem to remember that 6.2s had a tendency to warp the heads, but maybe that was only the early ones. There were rumors that driving them hard before being fully warmed up would blow the head gasket, but I'm remembering way back to when new square body diesels were for sale.
    I thought you described the pressure as building at idle, where the turbo wouldn't make any pressure. Stock boost is what - 7psi? So you would need quite a modified setup to open the radiator cap with turbo boost. Plus, how would you pressurize the coolant with the intake charge, but not burn coolant when not in boost?
  7. imiceman44
    Aug 5, 2002
    22,045
    5,850
    Lincoln, CA
    Build(s):
    5
    It doesn't start building pressure until I start driving or revving up then it's a steady stream.
    And I didn't say I know what is happening just throwing ideas out.
    Now I am thinking maybe the turbo does have something to do with it.
    The tty bolts and the torque setting is for a normally aspirated engine and I put a turbo on it and I was pulling 8psi after I put it together maybe that's what is making the pressure escape?
  8. campfire
    Jun 7, 2013
    24,820
    13,962
    Build(s):
    3
    Your 8psi turbine is not capable of pushing into a 28psi cooling system. The water would be flowing into the intake, not the other way around. It can't be the cause of this problem.
    21.5:1 compression means 316psi in the cylinder even without ignition. I can't think of anything else with sufficient pressure to insert air into a pressurized radiator.
  9. imiceman44
    Aug 5, 2002
    22,045
    5,850
    Lincoln, CA
    Build(s):
    5
    Well decided to do one more test.
    I pressurized the system to 25psi and let it sit for a couple of hours, if the head gasket was blown it would hydro lock the engine.
    It didn't, so with the pressure still there I started the engine and it immediately started rising in pressure, which eliminates the theory that steam is building up the pressure so I am changing the water pump which turns out has a bad bearing, and I pulled the valve cover on the driver side to check the head bolts...
    5 were not tight enough.
    I had a mechanic friend helping me and I believe he missed the last round of torque on the 5 bolts.
    He swears he got them but well...
    I torqued them
    I will do the other side tomorrow and run it.
    My theory is that under the combustion pressure gasses are escaping where the bolts were not tight enough but coolant can come in
  10. JoshHefnerX
    JoshHefnerX 1/2 ton status Premium Member
    Jan 7, 2015
    4,402
    3,030
    Glendale, AZ
    Build(s):
    Hopefully that does the trick, and running w/ some bolts loose didn't warp the heads.
  11. imiceman44
    Aug 5, 2002
    22,045
    5,850
    Lincoln, CA
    Build(s):
    5
    I didn't run it long, I am still in the testing phase, so when I replaced the radiator because of a leak I was making sure it was just the radiator and I was right to check. All I was doing was warming up and driving around the block for 5 minutes.
    We will see once I work the passenger side head and check.
    JoshHefnerX likes this.
