TruckNutzDude
I've had 52's on my rig for about a year now and while I'm very impressed with the flex they seem to lack durability. The pack I'm using has 4 main leaves and the overload, the pack is completely unmodified except for the addition of a zero-rate in the center position and poly bushings. I finally got around to nut and bolting my rig after my last trail run and I noticed my driver side main leaf is all tweaked and that the leaves have gaps between them, this is normally refered to a "W"-ing the springs for you noobs.
My thoughts are to go with either a 56" spring pack with all or most of the leaves including the overload or put my 6" BDS pack back in and play with the mounting of the shackle and front eye to move the axle foreward more than it already it.
