How much does a cummins 6BT weigh?
that seems kinda light???
Detailed Description
Type: Cummins 6bt
Bore(mm):102
Stroke(mm):120
Displacement/cylinder(l):0.98
Cylinder:6
Displacement(l):5.88
Compression ratio:17.5
Suction type: Turbo
Standard power(kw):118
Rpm:2600
Max torque:558.6
Max torque speed(r/min):1500
Power. Hour fuel consumption ratio(g/kw. H): Standard-238;max torque:215
Smoke extent: <3.5
Weight(kg): Net-399;wet-423
Size:1035 x 711 x 865
I wonder if that includes accessories (A/C Alt P/S Fan), aftercooler and piping, and airbox ??? and the Flywheel/Flexplate??
The lighter weight sounds about right to me. You see thats the alure of a 6bt they are lighter than most diesels of simular power/displacment.
Thats not saying they are light, just when you think about putting them in a light duty truck, its a managable weight.
