i've just got the stock shackle up front with 4" lift springs. my shackle length is seriously limiting my articulation - you can see that the current angle is pretty sucky and in any sort of compression situation, it almost immediately hits the frame. in any droop situation, it's almost fully extended already.
i'd rather not increase the lift with the addition of the longer shackle - is that doable? what length should i run?
for what it's worth, i'm running a 38" tire with no inner fenders, but the exterior ones need a bit more trimming. i want to do the new shackles before i trim more tho, so i can figure out how much more needs cut.
