so I purchased a set of cheepy wheel dollies thinking my smooth painted concrete shop floor would be fine and play nice with them . . . . .
so I set a rolling frame and body k30 up on them . no drive line just axles / frame / springs / body panels .
started to push it around the shop didn't even make it 1 foot and 1 of the dollies bent were the wheel bolts to the main plate .
so I swapped them with 2 others I had that were a tad thicker and finished the move of the truck in the shop .
today I grabbed some 3/4"x3/4" angle I had and cut 2 lengths 1 for each end to pick up the 2 outer most bolt holes . drilled for them and added a 5th in the center .
now I picked up the rf corner and watched a un-modified unit flex back to normal with weight being removed . then I set the modified unit under and set it back down on it and
it didn't flex and squat like a pair of buckling knee's ready to fall out from under its self .
now I just need to do 3 more and pick up some extra bolts for the center 5th hole and then re-test the use in the shop and see what happens.
also before I even used them I removed the wheel axle bolt and tube and greased them good to help in rolling around . and A LOT LESS SQUEAKING ! ! !
it didn't flex and squat like a pair of buckling knee's ready to fall out from under its self .now I just need to do 3 more and pick up some extra bolts for the center 5th hole and then re-test the use in the shop and see what happens.
and this was a non bent wheel area unit .
