84CUCV
3/4 ton status
I have a 700, 400 and a 4l80e that need it. not looking to do a drop and fill. looking to get it all out and put all new atf in. so how is it done? thanks
Drop 2 quarts of oil out of your engine. Pour two in. You've contaminated the 2 quarts that you just put in. Doesn't really serve a point does it?Blue85 said:I don't understand what you mean by "correctly". I just measure how much is coming out and put that much new in the fill tube. The gallon jugs usually have a handly little scale on the side. Yes, the machine with the giant piston is handy, but in the end if you have the right amount of fluid in, what's the difference?
I can't see paying $60+ for something this simple.
dyeager535 said:Drop 2 quarts of oil out of your engine. Pour two in. You've contaminated the 2 quarts that you just put in. Doesn't really serve a point does it?
Correct. That's why you turn the engine on and off. Going a couple of quarts low in Park is no big deal. Running the pump dry is bad.dyeager535 said:I would not attempt to try and keep up the fluid level with a line disconnected for fear of running the transmission dry.
