FlatBlackBurb
okay so im rebuilding my drum brakes on my full floater. for those of you who were wondering i did indeed get the driver side drum off but it took a lot of work. when i took the two nuts (with that weird ring with the tabs between the two nuts) off the driver side they came out with very VERY little effort... niiether of them were tight. when i took the passenger side drum apart, the outside nut was all the way off and just hanging. the other nut was slightly tighter than the first. but whats the order of tightness? its been a while since i did my 60 i thought it was that the inside nut is snug, then the ring with the tabs on it, then the outside nut is supposed to be as tight as you can get it? or is it the other war around?
