What is the best way to mount a ram with these type of ends? I am assuming some tabs that fit the opening? It's aprox 1 1/8" gap. Seems like that might be noisy..
Picked this up today 4' of 3.5x1
Ok coolPicked this up today 4' of 3.5x1
please tell me you're going to use a 4.5" angle grinder and a battery powered drill to make tabs from this.![]()
you'd spend more on cut off wheels and replacement batteries than it would've cost you to just buy a kit from Kert!
I used this:
http://diy4x.com/cart/index.php?route=product/product&path=17&product_id=109
And it has worked great for years.
DD? No leakage? I'll by doing hydro-assist but I'm not 100% sure on using a diff cover mount - would you use the same method if you were to do it again? Just looking for positive reinforcement.![]()
Whew my arm is tired
______
Next comes the joy of drilling a 1" hole![]()
The torch cuts really do look nice. I've never cut anything that thick with a torch and the cuts sure weren't that pretty! Looks good.
Whatever its better than cut off wheels
