GsxrMike
In another post I have talked about problems with my driveshaft angles. I was wondering if I went with an ORD engine crossmember and motor mounts if I could lower the crossmember by maybe 1" to 1.5" by installing a spacer between the crossmember and frame. I could then in turn lower the t'case crossmember a bit and possibly acheive better angles and a slightly lower COG. What does everyone think?
