F-N MICE..
It's getting to the time of year here when the dam rodents start moving to warmer quarters..
None have appeared in my house yet--but I'm sure they will soon..
Yesterday I walked by my late parents '93 Dodge Caravan,its been parked off the driveway under trees since my mom passed in 2013...I noticed something "hanging" near the rear side window...
I unlocked the door and was greeted by a wood spider about 3" in diameter,
--killed that,then was disgusted ,to see the whole headliner was ripped open all the way across above the front seats,and was sagging badly in the rear..
I've seen enough mouse nests in junkers at salvage yards to know right away what happened..
..the whole interior was practically mint in this thing ,and was fine the last time I checked to van about a month ago--to make sure no vagrants were using it for a crash pad.
Every month or so I try to start it up so it wont seize up--last time was back around March though,I put a battery in it and it started after cycling the key several times--the starter had a dead spot for a good year before it was parked but it always started,you just had to turn the key several times..(probably the solenoid ?)...
Anyway it did start,ran crappy on the old gas in it ,it was very close to empty "low fuel" light was on...I tried to move it and it felt like the tires sunk so deep it had a hard time pulling out of the ruts..got it about 3 feet forward so it wouldn't be lying on dry leaves and let it run awhile..shifter shaft in the transmission was starting to bind up so I lubed it with some penetrating oil,so the cable wont break..
I tried to steer it, and it felt like the colum was seized up solid !--I don't know if it has a u-joint in the steering colum,or if the rack seized up..nice..this will make getting it out from where it is parked difficult because it is 90 degrees to the driveway with a retaining wall --unless a ramp truck can pull "sideways" ..
I was torn whether to keep this thing from day one,it has only 94K on it but needs a lot of work--all the brake lines,gas tank looked punky,oil pan too,and the starter,valve covers leak--now that is sat so long all the calipers ,etc will be seized,and it already had the door bottoms patched up...its junk..
I held onto the Caravan this long hoping scrap prices would go up--right now they aren't that great but higher than before--I might get $250 for it scrapping it,but thats if I could deliver it--if they came and got it I'd get less..
I guess its time for it to go--hate seeing it get junked,but I advertised it long ago on Craigslist and got zero replies...not many of these vans left around here now..no one needs parts or wants to fix one up..lot of good times & memories in that thing,it took me to many concerts,hauled garden tractors home in it,and all the trips with my parents,they bought it new in '93..
Now I have to go look at my Chevy van and the '85 Suburban and I'm praying the bastards haven't already infested them too--they were OK a few weeks ago,but that doesn't mean much...even if I parked them in my garage,the mice would still get in them,I've found nests in the garage several times..
An air cleaner I had up on a shelf was FULL of some kind of nuts,and another one was "home".stuffed full of shredded cloth,and mice were also living in the shop vac dirt container!..
No more feral cats around here now,they all died of old age,or got killed by coyotes..didn't have any mice problems in my vehicles when they were around..
Even my pickup I drive daily had a nest under the insulation on the hood,and the engine has shelled nuts all over it...
It was only 45 degrees here at 6 am today!--furnace came on during the night,I had it set at 50 degrees and most of the windows were open...similar temps tonight too,highs only in the 70's this week,so this might be the week the dam mice start moving indoors..hate the F-N things,you cant poison them because they'll die in a wall cavity or in your vehicle,and trapping them is a pain in the a$$...nothing I try repelling them with seems to work either,like moth balls,etc--only thing I have yet to try is peppermint oil ,I hear that works,but I know of no place to buy any..
--killed that,then was disgusted ,to see the whole headliner was ripped open all the way across above the front seats,and was sagging badly in the rear..I've seen enough mouse nests in junkers at salvage yards to know right away what happened..
..the whole interior was practically mint in this thing ,and was fine the last time I checked to van about a month ago--to make sure no vagrants were using it for a crash pad.Every month or so I try to start it up so it wont seize up--last time was back around March though,I put a battery in it and it started after cycling the key several times--the starter had a dead spot for a good year before it was parked but it always started,you just had to turn the key several times..(probably the solenoid ?)...
...I held onto the Caravan this long hoping scrap prices would go up--right now they aren't that great but higher than before--I might get $250 for it scrapping it,but thats if I could deliver it--if they came and got it I'd get less..
I still need to improve it by using heavier gauge tin because they’ve been chewing on the aluminum and bending it.
..bet it has a bad hangover!..
