Nothing was changed except programming!I have a question about the lean burn thing ... while it exists in the software, were there any physical difference to the engine, or none, and can that be documented and proven?
I ask this because I was thinking about my Typhoon with the oil squirters. How do I know that the ECU change was also not accompanied by some mechanical addition like oil squirters? If I enable it without other possible required safeguards, it would be foolish and probably cause long term damage.
The lean cruise went away after a few years, now it's back! Don't know when but the LS PCM have the capability, just not the code. But Holdens in Austrailia do have it and it's on.
This thread really took off, cool!
Good note on the oil cooling pistons! It is the only cooling they have, water jackets in cylinders walls keeps them under control but oil only for pistons. You can really push spark limits in cruise if you can measure EGT and or oil temps. Oil temps will lag behind EGT but prove the point of to much timing, there is a certain point where detonation can occur without creating knock, it's a sweet spot you want to stay away from. hence find knock and back away at least 2 degrees.
There is a lot of room for more timing in our trucks without hitting knock, reason it's not there is emmissions. Now you have to be careful to add as a truck pulling a trailer will not take as much timing as same truck without. Same for comparable trucks, one on stock tires and one with huge heavy tires. Proper gearing gets them closer but all the weight of tires and wheels is still a factor, have to turn all that weight plus move truck!
I thought carb trucks ran a 180?great discussion guys
I'm just carbed so I guess my options are more limited. I will run through that checklist of basic stuff just to make sure I'm doing all I can. I love checklists, CK5 should make some more.
I did just switch to a 180* tstat, just because it was routinely running warmer than 210 with the 195*. a little early to tell, but it seems like the 180* might do the trick.
Before you jump in might want to check and see if gauge is accurate and sender is in correct location.
Carb engines are much more forgiving then EFI when it comes to lowering T stat temps. EFI thinks the engine is not warmed up and adds fuel as choke!
